2015-09-17, 15:20
Witam Mam taki problem. Mam zaznaczony element wyciągniecie, potem wlaczam makro i chce aby to makro dla zaznaczonego elementu dodało mi w liście cietych elementów jakąś słasciwosc. Pozdrawiam Janusz Zaba |
2015-09-18, 07:36
Czy naprawdę nie ma możliwości sprawdzić który element jest powiązany z która własnościa z listy elementów ciętych. |
2015-09-18, 14:53
'SolidWorks API Help 'Get Solid Bodies from Cut List Folders and Get Custom Properties Example (VBA) 'This example shows how to get the solid bodies from cut list folders and how to get the custom properties for the solid bodies. Option Explicit Dim swApp As SldWorks.SldWorks Dim swPart As SldWorks.ModelDoc2 Dim swFeat As SldWorks.Feature Dim Indent As Long Sub GetFeatureCustomProps(thisFeat As SldWorks.Feature) Dim CustomPropMgr As SldWorks.CustomPropertyManager Set CustomPropMgr = thisFeat.CustomPropertyManager Dim vCustomPropNames As Variant vCustomPropNames = CustomPropMgr.GetNames If Not IsEmpty(vCustomPropNames) Then Dim NameFmt As String NameFmt = "!" & String(30, "@") Dim TypeFmt As String TypeFmt = "!" & String(6, "@") Dim ValFmt As String ValFmt = "!" & String(80, "@") Dim ResValFmt As String ResValFmt = "!" & String(40, "@") Debug.Print String(Indent + 3, " ") & "Cut List Custom Properties :" Dim i As Long For i = LBound(vCustomPropNames) To UBound(vCustomPropNames) Dim CustomPropName As String CustomPropName = vCustomPropNames(i) Debug.Print Format(String(Indent + 6, " ") & CustomPropName, NameFmt); Dim CustomPropType As String CustomPropType = CustomPropMgr.GetType(CustomPropName) Dim CustomPropVal As String Dim CustomPropResolvedVal As String CustomPropMgr.Get2 CustomPropName, CustomPropVal, CustomPropResolvedVal Debug.Print Format(CustomPropVal, ValFmt); Debug.Print Format(CustomPropResolvedVal, ResValFmt) Next i End If End Sub Sub DoTheWork(thisFeat As SldWorks.Feature, ParentName As String) Static InBodyFolder As Boolean Static BodyFolderType(5) As String Static BeenHere As Boolean Dim bAllFeatures As Boolean Dim bCutListCustomProps As Boolean If Not BeenHere Then BodyFolderType(0) = "dummy" BodyFolderType(1) = "swSolidBodyFolder" BodyFolderType(2) = "swSurfaceBodyFolder" BodyFolderType(3) = "swBodySubFolder" BodyFolderType(4) = "swWeldmentSubFolder" BodyFolderType(5) = "swWeldmentCutListFolder" InBodyFolder = False BeenHere = True bAllFeatures = False bCutListCustomProps = False End If 'Comment out next line to print information for just BodyFolders 'bAllFeatures = True 'True to print information about all features 'Comment out next line if do not want cut list's custom properties bCutListCustomProps = True 'True to print cut list's custom property information Dim FeatType As String FeatType = thisFeat.GetTypeName If (FeatType = "SolidBodyFolder") And (ParentName = "Root Feature") Then InBodyFolder = True End If If (FeatType "SolidBodyFolder") And (ParentName = "Root Feature") Then InBodyFolder = False End If If (InBodyFolder = False) And (FeatType = "CutListFolder") Then 'Only consider the CutListFolders that are under the SolidBodyFolder Exit Sub 'Skip the second occurrence of the CutListFolders during the feature traversal End If If (InBodyFolder = False) And (FeatType = "SubWeldFolder") Then 'Only consider the SubWeldFolder that are under the SolidBodyFolder Exit Sub 'Skip the second occurrence of the SubWeldFolders during the feature traversal End If Dim IsBodyFolder As Boolean If FeatType = "SolidBodyFolder" Or _ FeatType = "SurfaceBodyFolder" Or _ FeatType = "CutListFolder" Or _ FeatType = "SubWeldFolder" Or _ FeatType = "SubAtomFolder" Then IsBodyFolder = True Else IsBodyFolder = False End If Dim FeatNameFmt As String FeatNameFmt = "!" & String(42, "@") If (FeatType = "FtrFolder") And (InStr(1, thisFeat.Name, "___EndTag___", 0) > 0) Then 'This is the folder End Tag Indent = Indent - 3 End If If bAllFeatures And (Not IsBodyFolder) Then Debug.Print Format(String(Indent, " ") & thisFeat.Name, FeatNameFmt); Format(FeatType, "!" & String(18, "@")); Dim vSuppressed As Variant vSuppressed = thisFeat.IsSuppressed2(swThisConfiguration, Empty) If IsEmpty(vSuppressed) Then Debug.Print "IsSuppressed2 failed"; Else Debug.Print Format(IIf(vSuppressed(0) = False, " ", "Suppressed"), "!" & String(15, "@")); End If End If If IsBodyFolder Then Dim BodyFolder As SldWorks.BodyFolder Set BodyFolder = thisFeat.GetSpecificFeature2 Dim BodyCount As Long BodyCount = BodyFolder.GetBodyCount If (FeatType = "CutListFolder") And (BodyCount < 1) Then Exit Sub 'When BodyCount = 0, this cut list folder is not displayed in the 'Feature Manager design Tree, so skip it Else Debug.Print Format(String(Indent, " ") & thisFeat.Name, FeatNameFmt); Format(FeatType, "!" & String(18, "@")); vSuppressed = thisFeat.IsSuppressed2(swThisConfiguration, Empty) If IsEmpty(vSuppressed) Then Debug.Print "IsSuppressed2 failed"; Else Debug.Print Format(IIf(vSuppressed(0) = False, " ", "Suppressed"), "!" & String(15, "@")); End If End If If Not bAllFeatures Then Debug.Print Format(String(Indent, " ") & thisFeat.Name, FeatNameFmt); Format(FeatType, "!" & String(18, "@")); vSuppressed = thisFeat.IsSuppressed2(swThisConfiguration, Empty) If IsEmpty(vSuppressed) Then Debug.Print "IsSuppressed2 failed"; Else Debug.Print Format(IIf(vSuppressed(0) = False, " ", "Suppressed"), "!" & String(15, "@")); End If End If Dim BodyFolderTypeE As Long BodyFolderTypeE = BodyFolder.Type Debug.Print Format(BodyFolderType(BodyFolderTypeE), "!" & String(28, "@")); Format(BodyFolderTypeE, "!@@@@"); Debug.Print Format("Body Count " & BodyCount, "!" & String(15, "@")) Dim vBodies As Variant vBodies = BodyFolder.GetBodies Dim i As Long If Not IsEmpty(vBodies) Then For i = LBound(vBodies) To UBound(vBodies) Dim Body As SldWorks.Body2 Set Body = vBodies(i) Debug.Print Format(String(Indent + 3, " ") & Body.Name, "!" & String(32, "@")) Next i End If Else If bAllFeatures Then Debug.Print 'Finish off pending print line End If End If If (FeatType = "CutListFolder") Then If BodyCount > 0 Then 'When BodyCount = 0, this cut list folder is not displayed 'in the FeatureManager design tree, so skip it If bCutListCustomProps Then GetFeatureCustomProps thisFeat 'Comment out this line if you do not want to 'print the cut list folder's custom properties End If End If End If If (FeatType = "FtrFolder") And (InStr(1, thisFeat.Name, "___EndTag___", 0) < 1) Then 'This is the folder start marker Indent = Indent + 3 End If End Sub Sub TraverseFeatures(thisFeat As SldWorks.Feature, isTopLevel As Boolean, ParentName As String) Dim curFeat As SldWorks.Feature Set curFeat = thisFeat Indent = Indent + 3 While Not curFeat Is Nothing DoTheWork curFeat, ParentName 'Do the thing that we are doing this feature traversal for Dim subfeat As SldWorks.Feature Set subfeat = curFeat.GetFirstSubFeature While Not subfeat Is Nothing TraverseFeatures subfeat, False, curFeat.Name Dim nextSubFeat As SldWorks.Feature Set nextSubFeat = subfeat.GetNextSubFeature Set subfeat = nextSubFeat Set nextSubFeat = Nothing Wend Set subfeat = Nothing Dim nextFeat As SldWorks.Feature If isTopLevel Then Set nextFeat = curFeat.GetNextFeature Else Set nextFeat = Nothing End If Set curFeat = nextFeat Set nextFeat = Nothing Wend Indent = Indent - 3 End Sub Sub main() Set swApp = Application.SldWorks Set swPart = swApp.ActiveDoc Debug.Print "File = " & swPart.GetPathName Dim ConfigName As String ConfigName = swPart.ConfigurationManager.ActiveConfiguration.Name Debug.Print "Active Configuration Name = " & ConfigName Indent = -3 Set swFeat = swPart.FirstFeature TraverseFeatures swFeat, True, "Root Feature" End Sub |
